What exactly are you looking for? I have any diagram you could possibly need but I need to know exactly what you want. What are you trying to do?
Billy
I have a 95 sl1 automatic with 155k miles on it. I was driving today and I noticed a funny burning smell... kind of like burning rubber, but not quite. It kind of had a sort of a burning hot metal smell to it, it that makes sense. I had been driving for a while and the engine was hot. the RPMs dropped very low when I came to a stop. the temp gauge went up over the halfway point. It started shifting gears erratically and the SES light came on. I pulled over to check it out. Tranny fluid was good, oil level good, belt seemed to be in ok shape. I couldn't see any obvious problems. I read the engine codes and I got a tranny code 23 (no 3rd gear.)
It may have been my imagination, but it seemed to me that I had to brake much harder to get the car to stop and that the steering was looser. I also go a nasty lurch from the change in gear when I slowed to make a stop.
I had previously noticed recently that the RPMs always seemed much lower than they should be while idle, especially when the engine was warm.
I have also gotten the same tranny code several times before.
Any ideas what the problem could be?Read More
Does anyone know how to install an air filter on a 2002 Chevy Impala?
The car's manual refers to opening some tabs on the housing after removing the spring clips. Where are the tabs and how can I unhook them? Any insight/tips are certainly appreciated!Read More
