96 camry A/C hose replacement - help
Old 04-04-05, 08:14 AM
Question 96 camry A/C hose replacement - help
My '96 toyota camry station wagon has been having A/C problems since last summer. I refilled the A/C three times last summer. Then I found a leak in the lower pressure line. Both the car shop and the dealer wanted to charge me about $90 just to find the leak and give me an estimate. I was thinking that I needed this car for about another year. It didn't make sense to spend more on it.
Now, I want to fix it, since I may need it for two more summers.
Does anyone has replaced the A/C hose(s) for this car?
I would like to know how easy it is to do it myself. Is there any type of protection gear I should wear?
For those who had this done by a car shop or dealership, what is the cost? 200? 500? more?
Thanks.
Old 04-04-05, 10:15 AM
1) Are you aware that A/C system cannot be just opened to the air? Freon needs to be captured and recycled.
2) After replacing the hose, you still need to pull the vacuum. Do you have a vacuum pump and hose/gauge set?
3) It is advisable, as far as I know, to replace drier once the system is opened to air (moisture). Can you do that yourself?
I recently paid about $650 for compressor job. If you subtract the price of compressor (about $300?), repair cost will be much less than 500. Good luck with the repair.
Old 04-04-05, 10:18 AM
No, I didn't know any of those. I am glad that I asked. Thanks.
