rattle - catalytic convertor?
dad-man1's Avatar
04-05-05, 08:53 AM   #1
dad-man1
I have a 1988 Ford Ranger w/2.9-V6 it only has 181,000 miles and EVERYTHING is original (except a new muffler & tires). Within the last month I've noticed a rattle from around the catalytic convertor area (also very close to the transmission area). It sounds like someone is taking a 9/16" open end wrench and tapping it against my catalytic convertor. It happens just about any time but not all the time: at idle, start of acceleration, running down the road; but it's sporadic. Is this the convertor or is my throw-out bearing beginning to go bad? The clutch and drivetrain have not changed in performance since I've had the vehicle, it all runs good--I just don't know where the rattle has developed from. Can anyone help?
Thank you.
markdiy's Avatar
NJ
04-05-05, 09:20 AM   #2
It certainly could be the cat. I'm no mechanic, but I had one go bad on each of my cars last year (cheap gas?). One of them sounded like marbles rattling around in a can. I didn't really notice any performance issues with the car, it just sounded bad. The other one melted down and became plugged. I heard no noise but seriously lost all acceleration of the car. I could not go more than about 40 mph.
One way to tell if it's a bad cat is to rap it gently with a rubber mallet. You may be able to hear the guts rattling around. Good luck.
comp's Avatar
04-05-05, 11:21 AM   #3
at 181k i'd bet it is,,, look and see that it's not just the shield though
slickshift's Avatar
04-05-05, 12:33 PM   #4
'88 Ranger?
I'd put money on a loose/rusted heat shield
Easy enough to check if you crawl under it
With that kinda miles could be the cats...
hopkinsr2's Avatar
Non-US
04-05-05, 09:03 PM   #5
I've got to agree with Slickshift. Chech the heat shields on the exhaust & dont forget about the one on the side of the transmission
dad-man1's Avatar
04-06-05, 01:53 PM   #6
dad-man1
problem solved
It was a rusted heat shield that was causing the rattle. Thanks to everyone!
