Cavalier transmission
rtta51's Avatar
04-07-05, 03:52 AM   #1
rtta51
undefined Someone please help! Have a 96 cavalier. Replaced auto trans (3T40). When engine gets up to temp the trans seems to lock up, when putting into any gear from park,engine shudders and stalls. trans noise comming from torque converter area. I did ajust the TV cable. Anyone know whats causing this? Thanks in advance for any help.
carguyinva's Avatar
VA
04-07-05, 04:01 AM   #2
stalling when...
...putting in gear sounds like a bad torque converter clutch solenoid. the solenoid is located inside the side cover...behind the LF wheel. not a big deal to replace and a very common failure on GM.
rtta51's Avatar
04-07-05, 04:30 AM   #3
rtta51
96 cav trans problem
undefined Thanks for the reply. This car will be the death of me. Would you have a ling to getting the parts for this fix? Thanks again.
carguyinva's Avatar
VA
04-07-05, 04:34 AM   #4
not without searching...
...which you can do. try calling your local parts distributor or dealer.
rtta51's Avatar
04-07-05, 05:15 AM   #5
rtta51
gotcha, thanks
