Fuel System Problem
Old 04-07-05, 05:41 PM
csulasoccer2003
Exclamation Fuel System Problem
I have a 94 Toyota Corolla 1.8 Fuel Injected system. When I am driving a long distance usually freeway driving, I will be "cruising" constantly holding the gas pedal in the same spot, after a while my car will then start to constantly "hiccup" or "burp" increasing RPM's and speed, then slowing back down quickly. This happens nearly 60 times a minute and lasts until I arrive at my destination. Can anyone point me in the right direction as to what might be the first thing to look at, or what in fact is the problem. I assumed that it was a fuel problem, but have never worked with a fuel injection system. I didnt think that it would be a transmission problem, but if anyone has any information, that would be great!! Thanks
Old 04-07-05, 11:11 PM
We need a repair history, parts replaced (brands also), mileage etc.
Pull codes,
DIAGNOSTIC TROUBLE CODE CHECK
1. Turn ignition switch ON.
2. Using SST, connect terminals between TE1 and E1 of the
data link connector 1 under hood
