Whine Through Radio During Acceleration
Old 04-08-05, 10:08 AM
cowzz
Hey Folks...
When I turn the radio on in my truck (1989 Chevy 1500), I hear a whine through the radio that is in synch with the acceleration. The more I accelerate, the louder the whine. I have heard that this is an alternator problem, but the alternator is less than two months old. Is there a suppressor I can install? Thanks for the help..
Mike D.
Old 04-08-05, 01:44 PM
AM or FM ?
Old 04-11-05, 07:44 AM
cowzz
AM, FM.. Most of it's crap nowaday's anyway. Maybe I'll replace the radio with a 36 inch flat screen.
Old 04-11-05, 07:46 AM
cowzz
Sorry.. FM, haven't tried AM.
Old 04-11-05, 08:05 AM
Elizabethl
This is a pretty common problem in Chevy trucks these days, and yes its from the alternator.....you can install an in-line noise filter (available at radio shack or anywhere sound systems are installed)....just follow the instructions on the package....the installation is pretty painless....and enjoy your tunes dude!
Old 04-13-05, 02:18 PM
Elizabethl
Just wanted to check with you.......did you get your problem fixed???
Old 04-13-05, 03:42 PM
GlassesRx
OK, i'm sure some of the guysgals can help me out here. Is there a part on a '89 distributor that reduces alternator noises? It's a small silver cylinder under the rotor. I had to change mine way back when, memory fades! LOL If not, do you have any amps installed? If so, ditto on the above feedbacks, install an inline noise suppressor. Check your grounds from your stereo,amps,and speakers and make sure all the connections are clean and solid. My two cents
Old 04-13-05, 07:31 PM
jcthefirst
check your power wires
If you have any amps make sure the speaker wires are ran on one side of the truck and your power wires are ran on the other side.
Old 04-14-05, 07:00 AM
Bob53's Avatar
HI GlassesRX ....is that part under the distributor cap your speaking of called a "condenser?". I'm kinda jogging my own memory here also.
-Bob
Old 04-14-05, 01:23 PM
Try "capacitor"
Old 04-14-05, 01:41 PM
the older model hei distributers that gm used up to around 87 did have a condensor or noise suppressor the newer distributers do not have this component.
plug wires may cause radio noise also you may look at them if its not coming from the alternator.
Old 04-14-05, 09:19 PM
Even new ones, if they are not the right kind
