90 Camry elec.window
Old 04-08-05, 12:21 PM
Lightbulb 90 Camry elec.window
The elec. window motor in the driver's door of a '90 Camry is dead.
Does the regulator have to be removed in order to change out the motor? I
reached behind the regulator to unscrew the motor but a 4mm Allen was too small and a 5 was too big. I'm sure I'm doing something wrong.
If I remove the regulator will the window drop?
Old 04-08-05, 12:42 PM
You do have to remove the regulator and the window will drop.
Be careful when removing the motor the regulator is spring loaded.
Old 04-11-05, 12:20 PM
Thumbs up Thanks
Thank you, Larry
I duct-taped the glass to the window frame and removed the whole
thing. Easier than I expected, but a chore, nonetheless.
Thanks again
Jim
