Clearing Computer Codes on 1996 Olds
SuzyQuzy's Avatar
04-08-05, 03:43 PM   #1
SuzyQuzy
Can anyone tell me how to clear the computer code on a 1996 Oldsmobile 88 with a V6 engine so my "check engine" light will go off? Will appreciate any help offered. Thanks.
hopkinsr2's Avatar
Non-US
04-08-05, 07:18 PM   #2
Tell us what engine & what the codes are. If it's OBD2, you'll have to fix the problem first
Mr. Dummas's Avatar
04-08-05, 07:28 PM   #3
Yup. OBD2 would require a repair to clear, unless a number of ignition cycles were met, it will clear itself--depending on the DTC (code).
the_tow_guy's Avatar
FL
04-09-05, 05:56 AM   #4
Visit your local Auto Zone if you have one. They can both read the code (so you can tell us what it is) and clear it. As noted, unless you fix the problem, the light will come back on.
Measure it with a micrometer; cut it with an ax.
smokeejoe's Avatar
04-10-05, 09:57 AM   #5
smokeejoe
maybe an easy fix?
Try unhooking your battry ground for 5 minutes, and putting it back on. Turn your key to the run positiom, ( DONT START IT! ) count to 5, turn it off for 30 seconds, now start car. It worked on mine, hate that pestky Check Engine lite.
SuzyQuzy's Avatar
04-11-05, 12:41 PM   #6
SuzyQuzy
SmokieJoe....Thanks for the help. That's pretty much the answer I've been looking for. Much appreciated. SuzyQuzy
pmgheritage's Avatar
04-11-05, 05:02 PM   #7
Posted By: SuzyQuzy SmokieJoe....Thanks for the help. That's pretty much the answer I've been looking for. Much appreciated. SuzyQuzy
Even if it's the wrong answer? (i.e. won't work)
