1995 Chevy Silverado 1500
Old 04-10-05, 10:22 PM
Ira
Hey, it's me again.
I cannot get my in-front of the radiator mounted horn to work. I tried replacing the unit to no avail.
I have checked the fuse panel descriptions and there is no listing for the horn. I am left to using friendly hand gestures and beginner's telepathy to communicate with fellow commuters.
Any suggestions about how I can get my truck's horn to function properly?
Thanks a bunch!
Ira
Old 04-11-05, 05:49 PM
There is a fuse for the horn, take another peak in the owners manual. You could take a test light and connect it to ground, while backprobing the horn connector. Then press the horn button to see if the test light lights. If not, suspect a bad wire or a blown fuse. If it lights, check the ground of the horn.
Old 04-19-05, 04:52 PM
jcthefirst
Horn
Check the clock spring behind the steering wheel.
Old 04-19-05, 09:09 PM
stittumscrib
hey! hey !
could be the horn relay!
