1985 Jag
1985 Jag
I have a 1985 Jaguar Xj6 that I have been unable to start this spring after storage over the winter. The battery was bad and I have replaced it, however it seems that I am not getting any spark to the cylinders. What is the best order of replacement to get it to start? coil?
Thanks
Thanks
First see if you can coax a spark AT the coil. Remove the wire running from the coil to the center of the distributor at the distributor end and hold the free end close to a ground source. Have someone crank the engine and see if you get a spark. If you do, the problem is either cap, rotor, or plug wires; all of which are probably cheaper than a coil. If that is a points and condensor set-up (vice electronic ignition) replacing both would be a good idea, but make sure you know what the setting should be on the points before you tear into it.
