bad running 429ci ford!
Old 04-17-05, 08:23 AM
papas
Angry bad running 429ci ford!
71' Ford T'Bird,429ci thunder jet,53000 org'l miles,always gargaged & serviced at a ford dealership(always). MY folks gave it to me & it ran fine for about a yr,then started running rough,died at lights & etc. Did the following: plugs,points,cond's,cap,rotor,wires,rebl'd carb,set timing,new vacuum adv's,checked & fixed 3 vacuum leaks(18lbs now),set choke adjm't. Now,if you don't keep it running @ high rpm's when starting cold, till it warms up,it will flood out & die or back-fire up thru carb. Even when warm it still runs real bad! as of this post I have not took a compression test which is next! Any ideas as to what i'm missing? I have rechecked firing order,timing and etc.THANKS in advance!
Old 04-17-05, 06:24 PM
How's the tailpipe look?
Any black soot around it?
Did you test the coil?
Also did you check to see if the timing chain was off or sloppy?
I mean, did you get the #1 [email protected] and the pointer was @ 0* with no play in it?
If it jumped a tooth or something...
Old 04-18-05, 10:15 AM
papas
Lightbulb stay tuned slickshift!
Will check your suggestions,& post results when weather breaks,soon I hope
