dodge truck
Old 04-18-05, 06:47 AM
sailor 57
Exclamation dodge truck
any one have ideas on how to locate a vacuum leak to transmission i have a 1990 d-150 2wd w/3.9lL 6 cylinder i am having trouble w/hard shifts feels like a vacuum problem any ideas?
Old 04-18-05, 06:10 PM
New guy's Avatar
I don't think you have any vacuum hose to your tranny like the one on Ford has, you may look at the throttle cable/linkage at the throttle body and make adjustment if necessary.
Old 04-18-05, 08:46 PM
wayne141
I agree, dodge doesnt use vacuum. check cable or linkage. if its a cable, you can push in a square botton right where the cable mounts on engine, and slide the cable in and out. I think the linkage might be threaded.
Old 04-19-05, 06:06 AM
sailor 57
Smile dodge truck
thanks for this info i'll let you know how this turns out
Old 04-27-05, 06:33 AM
sailor 57
Smile dodge truck
thanks again as it turns out the throttle linkage eas hanging up not allowing the trans to shift properly.
