Heat/Ac fan not working in 03 Impala
paradis2's Avatar
04-20-05, 02:53 AM   #1
paradis2
At first it would work sometimes, but now it does not blow out any air. You can feel heat or ac filter out, but that's it. What would be the most likely cause? Fan motor?
Thanks
davo's Avatar
04-20-05, 01:10 PM   #2
Blower motor resistor or the fan motor is the most likely problem.
michael van's Avatar
TX
04-20-05, 02:03 PM   #3
Filter?
Did you say you can feel air with the cabin filter out?If that is the case clean or replace it probbaly pluged up.
paradis2's Avatar
04-21-05, 10:07 AM   #4
paradis2
Thanks for the tip. I'll try replacing the resistor and see if that does the trick. I'm having a similar problem on my Cavalier too. Gotta love them Chevys!
