1990 Chevy power steering pump
I would like to replace my power steering pump on my truck. However, I'm not real sure how to get to the bolts behind it. So I think that I must remove the pulley first. HOW? is ther a bolt in it or an allen head type bolt.
Can you help?
Can you help?
puller
they make several pullers for this. the chevy has a slot on the pully that the puller slides into and simply tighten the bolt till it presses the pully off.
Thank you very much... For your help...
I guess that I will have to somehow press the pully back on with WHAT... another type of a tool... Is that correct...
Pulley Puller
Most power steering pullers are installers to. You should be able to use the same tool to install it. Autozone/Advance Auto Parts should have a loaner tool available.
Previous Thread
Next Thread
