Turn signals won't work/ 88 Gr Wagoneer
Old 04-22-05, 11:39 AM
jjammer18
I have an 88 Grand Wagoneer and my turn signals quit. I had the switch replaced[at Grand expense], 2 years ago. The hazards & turn signals are on the same fuse. The hazards work just fine.The signals won't work at all, not even light. Does anyone out there know how to diagnose the switch/problem?I have a multi-tester, but I can't find a manual, are there any links that can help me? Thanks for your help, Jeff
Old 04-22-05, 06:01 PM
I can't find a wiring diagram, but if you're sure the hazards and turn signals are on the same fuse, I'd replace the flasher to start with. It should be under $10. When you remove it, check the connections for rust or corrosion.
Old 04-23-05, 09:06 AM
jjammer18
Flasher
Flasher it is, they are so hard to see,[AND GET AT], that I didn't realize there were 2. Thanks a bunch. Jeff
