Heater blowing cold air
Old 04-24-05, 04:06 AM
tebe
I have a 1997 Plymouth Breeze 77,000mi. never really had any problems til today. After starting vehicle I noticed a clanging hear and there out of nowhere. It lasted a few minuites. Then I noticed blower was blowing cold air. I shut it off because windows started to frost up. I turned it back on and noticed heat for a few seconds then it started to blow cold air. Is thiis going to be a major problem? Heater core? If so is this difficult to fix.
Thanks in advance to any advice.
tebe
Old 04-24-05, 07:55 AM
It may blow cold due to being low on coolant. Check the coolant level, does the heat come back when the engine rpm's increase?
Also, it could be a mode door actuator of some sort under the dash, which is not allowing the door to open for heat from the heater core; I'm not too familiar with MOPAR's HVAC setup.
If it were the heater core plugged, I don't think that heat would be felt when you restarted the car.
