What These Letters Mean
chevyastro4x4's Avatar
SD
04-25-05, 07:23 AM   #1
can someone tell me what each of these letters mean
4.3L V6 TBI OHV 12V
ivantt's Avatar
04-25-05, 07:45 AM   #2
4.3L.......4.3 Litre engine
V6..........Six Cylinder, three on each side
TBI.........Throttle Body Injection
OHV........Overhead Valves, not overhead cam
12V.........12 Valves, two per cylinder
miltons's Avatar
04-27-05, 06:25 PM   #3
miltons
Tbi
What is throttle body injection?
SD
04-28-05, 12:43 AM   #4
A type of electronic fuel injection system that uses a single injector or pair of injectors mounted in a centrally located throttle body. The throttle unit resembles a carburetor except that there is no fuel bowl, float or metering jets. Fuel is sprayed directly into the throttle bore(s) by the injector(s).
rob24chevy's Avatar
04-28-05, 12:05 PM   #5
12 V is a 12 volt electrical system not (12 valves per cylinder) . How many cams would you need for that many valves per cylinder. lol.......... that would be a 72 valve engine.
slickshift's Avatar
04-28-05, 12:41 PM   #6
It could be volts or valves
In this case it looks like valves
It looks like all the letters are describing an engine
Not the electrical system
ASEPartsman's Avatar
04-28-05, 05:12 PM   #7
ASEPartsman
12 valves meaning two per cylinder (one intake, one exhaust, only one camshaft)
