Cavalier Window Winder Motor
Old 04-25-05, 03:59 PM
oldmedic
Can anyone post a chassis electrical diagram or link for 2000 Cavalier driver's side front window winder motor removal and replacement. I don't have a manual and the installation instructions with the new winder motor a really vague. Especially concerned about how to pin the spring before I remove the old motor. Thanks. oldmedic
Old 04-26-05, 01:37 PM
D
There is nothing to 'pin' to the best of my knowledge.If you require specific instructions please let me know.
Old 04-30-05, 08:11 AM
oldmedic
Nothing to pin, but..................
You were right "davo", there was no spring to pin in the Cavalier door. But, the new motor came with no instructions and only 4 screws to reassemble everything. It took five screws just to replace the rivets I had to remove from the motor and gear assembly and an additional 5 screws to replace the large pop rivets that mounted that assembly to the door framing. All in all about an eight hour job. I did discover a novel way to position nuts inside the door to screw to that I couldn't reach or see. I secured the nut with a length of "duck tape", fished it behind the panel, and gently started the screw from the other side all done in the drive way after 8 pm. What a father will do for his kids.
Old 04-30-05, 09:24 AM
B
Nice work guy.
Typically I'd use all rivets to reassemble that job. Not a fun one either. I think a flat rate tech would get maybe a little over an hour for that.
