Jeep problems
Jeep problems
I have a 94 cherokee w/ 4.0 and I am having problems with it stalling. I have went though and replaced the fuel pump, fuel filter, dist. cap, rotor, and lastly the coil.
It will run fine sometimes, for a day or so, then i will be lucky to get it out of my drive way and back in others. I have spent the better part of a week under the hood of this thing trying to figure it out, and i am now out of options, any suggestions would be greatly apprecated.
when does it stall (cold or hot), how often does it occur, does it get worse over time, can you start it right after it stalls, or do you need to let it cool down for a while ?
I have a 95 cherokee, had similar problems, it ended up being the cranksensor,
it was failing very randomly intermittently, and would start only after it was cooled down, would not give me error codes that would show the prob either. don`t know if thats your problem but maybe this input can help
markthehermit
markthehermit
