Toyman Q
Old 04-30-05, 05:15 AM
the_tow_guy's Avatar
Toyman Q
Since you're here.....
Is static in the radio on a Camry a common problem when using rear window defog (antenna in the window)? And is there any cure?
Old 04-30-05, 07:49 AM
Let me take a quess.....does the window have aftermarket tint?
Old 05-01-05, 03:55 PM
Negative. Standard window w/defog and integrated antenna. No tint.
Old 05-01-05, 11:47 PM
I have seen where too much urethane is used (what holds the rear glass in) and it touches the window grid. It makes a sort of connection to the body causing the interference in the radio when defog is on.
Old 05-02-05, 01:52 AM
Okay. Not going to lose much sleep over it. Don't need the defog that often and then only for short periods. It's an '01 w/less than 30k miles and in pristine condition that I picked up (stole!) for just over $9000, so I'm not going to sweat something that minor.
