Not sure what is going on with my Escort
Old 04-30-05, 08:03 AM
hopps10
I have a minnesota 99 Ford Escort Sedan, standard Transmission, 4cyl 2.0L FI (p) engine.
While I start driving my car on the freeway, when I get to 35 mph, my car starts hesitating until I get to around 55-60mph. I believe it might be the transmission. When the car is going from 0-30mpr it is fine. Only at excelerating speed is when it hesitates (starts jerking). If anyone has a good idea what is wrong please help me out. If it is a transmission problem, I would like to know if I should get the transmission fixed or start looking for a new car.
Thank You
Dan
Old 05-01-05, 07:09 AM
Get the codes pulled, even if the Check Engine Light is not lit
It will help with diagnosis, even if there are no codes
I think it sounds like a Mass Air Sensor is gummed up, but it really could be a number of things
Really the best place to start is pull the codes and post them here
Old 05-02-05, 04:02 AM
I
http://www.feoa.net
The best Escort website anywhere. On my Escort I can read codes by installing a jumper wire and watching a light. You need to look for stored codes and clean you MAF and IAC, at the very least. I'd also check the TPS. I don't think it's your transmission.
