1990 chev van 305 on propane
Old 05-01-05, 01:23 PM
L J
I changed plugs,wires,cap and rotor.I regaped plugs to .035 from .045 as to specs for gasoline.I have experienced a loss in power which I suspect is a dud plug or I need to open the gap on the plugs for propane. there is no backfire or missing.
Old 05-01-05, 05:45 PM
D
Did you change the
parts as part of a routine tune-up? If not, what was the problem you were trying to fix?
For a routine tune-up, double check and make sure that you didn't accidently mix up the wires going to the plugs or the connections at the distrubutor.
That's about all I can think of that would cause this, but I'm not an expert either!
