spark plugs on Toyota
Old 05-02-05, 05:52 AM
This is just a for my info question maybe Toyotaman Larry knows the answer.
I have a 2004 Toyota Tacoma with the 2.4L engine manuel 5 speed gear box.On that truck did Toyota use the Iridum plugs?The reason I ask is on my 2003 Matrix it has them.I looked in the owners manuel but found no mention of them.It just says the 2RZ-FE uses the Denso K16R-U11 or the NGK BKR5EYA-11.How often should these be replaced?
If they are not Iridium plugs I wonder why Toyota did not use them.
Old 05-02-05, 01:35 PM
They are regular and are due to be changed at 30k
Old 05-02-05, 02:24 PM
very well
Ok thanks for that info I will change them at around 30k then with the plugs they say to use at least they must be cheaper then the Iridans
