Replaced lower intake in 93 explorer now it sputters and backfires
Old 05-09-05, 03:37 PM
ofarrell
Question Replaced lower intake in 93 explorer now it sputters and backfires
I replaced the lower intake gasket in my 93 ford explorer due to a serious water leak. After putting it back together it runs really rough and backfires. I thought maybe the fuel had sat too long (it took a while to fix) and added STP but it didn't fix it. I'm not sure if the plug wires could be bad or just not in order. It has a coil not a distributer. I can't find a good diagram that shows the proper plug order and don't know how to test without a distributer. Any suggestions about the plugs or if replacing the gasket could have caused the problem? It ran great until the leak.
Old 05-09-05, 04:58 PM
If the spark plug wires are in the wrong order it would act as you say
I'd double check that
What engine is in there?
autozone.com probably has the firing order
