front end chatter
Old 05-10-05, 08:15 AM
STOMPER93
front end chatter
I have a 93 full size blazer 4x4. i have a front end shake that i cant find. It shakes at about 60mph and stops if i give it gas or let off the gas. I have checked the drive shaft for balance,and looked for any type of scaring or worn parts. can anyone help me?
Old 05-10-05, 11:39 PM
I find when there is shimmying at one speed only it is usually tire balance. Have someone turn the steering wheel while you try holding the tire still and see how much "play" you have or jack it up and holding in the 12/6 o'clock positions rock it in and out to see play in wheel bearing. Can be rack and pinion,ball joints, etc. but start with getting tires balanced.
