TN
05-10-05, 04:59 PM
Water dripping under dash while running a/c.
I have an '88 Isuzu Trooper and when I make a left hand turn while running the air conditioning, the water under the dash on the passenger side tends to drip onto the floor.
Is there something that's stopped up that needs to be cleaned out? Thanks for any help.
05-10-05, 08:58 PM
ASEPartsman
Your drain for your evaporator core is probably blocked up. To find where the drain tube is, run your a/c and look to see if there is ANY water coming from under the car. This is where the drain tube will be.
