Rusted rocker panels on 1998 Chevy Venture
Old 05-11-05, 01:54 AM
T
techtim
I have a 1998 Chevy Venture, 85K miles. I keep it clean and garaged, and rarely have driven on gravel roads.
I was disappointed to find that rocker panels on both sides of the van have rusted through in a small area about 6" in front of the rear tires. I think this is really poor quality to have such severe rust in only 7 years.
I got a quote from my Chevy dealer for $1900 to replace both rocker panels. I called Chevy's customer service to see if this would be covered by their 6 year 100k mile warranty. Got nowhere with that.
Are there any other alternatives? What about just having the rust ground out and repaired. Would this last?
Thanks, Tim
Old 05-14-05, 10:53 PM
U
Thumbs up
Thanks, Tim
Tim, sure you or someone could do the bodywork. Could either replace the panels or just repair them. I replaced the ones on my truck and did it rather cheaply! I have used bodyfiller on many repairs and have gotten good results if done correctly. Good body filler job should last quite some time if done correctly. I used a lot of bodyfiller on my car and that was 7years ago. It still looks good! So, it pretty much depends on how good of a job is done. Since rocker panels are on the bottom of the van sometimes they are painted a different color anyway. So, you could just fix them yourself and paint them a contrasting color like black? All depends on how good a job you want? Jack
Old 05-15-05, 03:28 AM
T
techtim
After getting several repair quotes, I am going to do something like this. The pocker panels are barely visible, so I don't mind doing a small repair myself. Also, this van is no longer our "main" family transportation. I use it as a work and hauling vehicle. If the repair isn't perfect, I won't worry. I hope to get another 3 to 5 years out of this vehicle, and paying for a professional repair just doesn't seem like a good use of $$$$.
Thanks for your reply,
Tim
Old 05-15-05, 09:06 AM
B
I fixed some holes in the bed of my pickup using tiger hair. Get the stuff that does not absorb moisture. Spread it out over a piece of plastic sheeting, the stuff you get your dry cleaning covered with. This is called a "taco". Pick up the plastic with the tiger hair in it, and apply it over the hole. After it's cured, spray some rock guard over it, which will leave a thick rubberized coating over it, and you're done.
Old 05-16-05, 09:53 AM
E
Plan a family vacation to Mexico, drive down and have the work done for about 1/10th of what it would cosr up here and they do fabulous work.
