97 LeSabre ignition key replacement
Old 05-13-05, 05:43 AM
C
coldbeer65
Question 97 LeSabre ignition key replacement
I just bought a 1997 Buick LeSabre and my question is about the ignition key. I only have 1 set of keys & want 2 more sets made. Apparently the key is for a security lockout system. Not familar with it. I have been told its a special key I have to get from G.M... Cost about $35 - $ 40???
I was told I would have to have a dealer make the keys.
Is there any way I can just get a less expensive key that will work & start the car. I don't really care about its security...
Thank you for any suggestions. Bob (coldbeer)
[email protected]
Old 05-13-05, 07:38 AM
G
Received 2 Votes on 2 Posts
Have you checked a local locksmith? If it's the key with a little black chip in it - you will see it near the top of the key - many locksmiths have a device which can read the code. They can then duplicate the key for about half the dealer's charge.
A plain key, without the chip, will not start your car.
Old 05-14-05, 06:17 AM
B
And if it's the kind with out the visible chip, look near the handle of the key where it might have PK3 stamped into it. If it does, u need to take it to the dealer.
