120k mile service
Old 05-13-05, 01:46 PM
Lightbulb 120k mile service
Hi,
I have a '97 Honda Accord with 120k miles on it. It had the water pump and timing belts changed at 90k. Is the 120k mile service worth getting??
greenda4
Old 05-13-05, 02:45 PM
DKM's Avatar
DKM
DKM is offline
In my opinion, yes. But what does your 120k maintenance include?
When I worked at a Honda Dealership ('88-'98) our 120k mantenance included a 131 point check list, plus LOF, Major tune-up (plugs, fuel filter, cap, rotor, wires & check/adjust valve lash), Transmission service, Check/lube brakes & calipers & Cooling system service.
Since the water pump was changed @90k you don't need the cooling system serviced, but I would do the rest of the 120k service. The Check/Adjust Valve Lash is a little technical & the fuel filter is a pain to do*! The rest of the items are easy DIY projects.
FYI; I believe the Fuel Filter on the '97 Accord, located on the firewall below the brake booster, is considered a lifetime componant, but we did them @120k mile maintenance.
That's my 2 cents worth,
David
