J-36607 Ball Joint Separator Tool
Old 05-15-05, 06:21 PM
T
taxman
I want to change the ball joints on my Blazer. The book says to use a J-36607 ball joint separator or equivalent. I assume the J- is a GM tool. What is the equivalet tool to use?
Thanks
Old 05-15-05, 07:02 PM
C
You don't say what year you are working on
The factory manual for a 95 blazer calls it a ball joint seperator and shows a less than great picture of it. It looks somewhat C shaped with 1 longer and 1 shorter leg. The shorter leg has a half circle cut out. However it is not mantioned or shown in the description of how to change the upper or lower balljoint?? It kind of looks like you hit it with a hammer but I can't really tell from the picture of it.
I believe you can just use a regular pickle fork type as long as you are replacing the ball joints and dont care if you ruin the grease boot
