replaced ford axle seal
Old 05-16-05, 04:11 PM
Received 203 Votes on 180 Posts
I have a 76 f-100 4X4 and just replaced the pass side axle seal. I'm not 100% sure I reinstalled the axle right. When in gear [it's still on stands] only the right[drivers] side turns. If you manually turn the left side the right side turns, manually turn the right side and only the right side turns. Is this normal or did I mess something up?
Old 05-16-05, 04:36 PM
If I am understanding you correctly, that's right
...does it have trac-lok?
Old 05-16-05, 04:45 PM
Wish it had limited slip but I guess it doesn't -- thanks
Old 05-16-05, 04:56 PM
...it would act the same when not under load
Ford Trac-Lok needs a shock to kick it in
Or reverse then fwd
