remove/replace blower motor 1998 Buick Regal
Old 05-17-05, 10:09 AM
spence4czech
need some guidelines in removing/ replacing blower motor. Car is a 1998 Buick Regal LS w/ ac..
Thanks in advance
Old 05-17-05, 06:56 PM
Its a tight fit. You'll need to first remove the lower insulator panel under the passanger side of the dash. Unplug the blower motor from the resistor module. There are 3 brass colored hex headed screws that you'll have to remove. They are size 7/32 or 5.5mm I believe. It may give you a little trouble coming out, but be patient and careful. Good luck.
