how do I program keyless remote for camry 2005
Old 05-17-05, 01:22 PM
meteore01
I just purchased a Toyota Camry 2005. One of the keyless remotes that came with the car does not work.
In order to avoid returning to dealer to have the second keyless remote programed, can some one advise step by step order how to program.
Thanks.
Meteore
Old 05-17-05, 05:48 PM
G
Received 2 Votes on 2 Posts
Is the dealer that far away? You have a bumper to bumper warranty on a new Camery and I would have the dealer make it right.
Old 05-17-05, 05:50 PM
It's not for the faint of heart but here it is
DOOR CONTROL TRANSMITTER
REPLACEMENT
1. REGISTRATION OF RECOGINITION CODE
HINT:
 The add mode is used to register a new recognition codes while still retaining codes already registered.
This mode is used to add a new transmitter. If the number of registered codes exceeds 4, the previously
registered codes will be erased in order, starting from the first registered code.
(a) Make sure that the vehicle fulfills the following conditions.
(1) No key is inserted in the ignition key cylinder.
(2) The driver side door is opened (The other doors are closed).
(3) The driver side door is unlocked.
(b) Select a mode.
(1) Insert the key into the ignition key cylinder, then pull it out (Perform this operation once again
within 5 seconds).
(2) Close and open the driver side door twice.
(3) Insert the key into the ignition key cylinder, then pull it out.
(4) Close and open the driver side door twice.
(5) Insert the key into the ignition key cylinder, then close the driver side door.
(6) To select a mode, turn the ignition switch from ON to LOCK twice at approximately 1 second intervals
Then remove the key from the ignition key cylinder.
Door locks will lock and unlock to confirm entry in the program mode.
Register the transmitter.
(1) Within 40 seconds after the add mode or the rewrite mode has been selected, simultaneously
press the LOCK and UNLOCK switches twice.
NOTICE:
Press and hold both switches for 1 second or more during each press. However, the time between
the 1st press and the 2nd press must be under 3 seconds.
(2) LOCK-UNLOCK operation is automatically performed once within 3 seconds after above operation
(step 1), when the recognition code of the transmitter has been registered correctly. If the
LOCK-UNLOCK operation is performed twice, the registration of the recognition code has failed.
In this case, register the recognition code from the beginning of the registration procedures once
Old 05-19-05, 09:44 AM
meteore01
Larry,
Thanks for taking the time to reply to my query.
Meteore
