'95 tercel fender replacement
badbatsbillie's Avatar
05-18-05, 03:31 PM   #1
badbatsbillie
I am having trouble putting on a new fender (front passenger side). The car ius a '95 toyota Tercel. Thank you to anyone that can help.
the_tow_guy's Avatar
FL
05-20-05, 04:42 PM   #2
You'll probably need to be a little more specific.
Remove the splash shield inside the wheel well; also easier if the wheel is off, but bve sure the car is properly supported. Should be a row of bolts on the top edge inside the hood plus a couple in the door hinge area and possibly down low under the door/fender joint area. Might also be some you can't see until removing the headlight assembly. Only so many fasteners that can be holding it on.
Measure it with a micrometer; cut it with an ax.
