wiring
Old 05-19-05, 05:41 AM
pjatteryd
wiring
need to put trailor wiring on chevy trackor,is there a place to plug it in and where
Old 05-19-05, 05:49 AM
carguyinva's Avatar
the rear lamp harness...
plugs in at the back of the vehicle somewhere...follow the wires that go to the bulb sockets back upstream til you find a connector.
you also should check with your local parts supplier to see if there is a harness adaptor available that will just plug into the existing harness...these are the best. if not, then you have to locate the harness...identify which wires do what and splice your trailer harness to the existing wires...kind of shade tree, but that's what some folks do.
Old 05-21-05, 03:08 AM
the wiring kit should come with instructions...
www.trailerwiring.com/inst/41245.pdf
http://hitches4less.com/19chevtractr.html
Old 05-21-05, 05:07 AM
There's no place to just plug in a trailer harness on that vehicle. You are going to have to splice in to attach a trailer connector.
Trackbacks are On
Pingbacks are On
Refbacks are On
