oil light
oil light
past 2 days oil light is coming on after i drive about 11 miles, then it comes on when i hit the brakes. Is my oil pump letting go or the sending switch? how
can i test for either problem?? 1997 Intrepid.
You need to get a shop to hook up a mechanical gauge directly to the engine, or you can get a mechanical gauge yourself/ hook everything up but do not mount it to your dash, just lay it on the floor. This will give you an exact oil pressure.
