Vehicle inspection
Vehicle inspection
Ok so my speed sensor is messed up. Im wondering if i will be able to get my vehicle inspected if my check engine light is on. I live in texas.
Thanks
Thanks
Checkout this link:
http://www.txdps.state.tx.us/vi/publ...is_require.htm
It may answer your question, and by the way even if you remove the battery cable and the CEL goes out, you will still need to put the vehicle through a drive cycle before it will pass. Every car maker has different requirments for it's drive cycle.
Hope that helps!
Hope that helps!
