'88 Ford F150 Tilt Steering
Old 05-29-05, 12:34 PM
Mike88F150
Can anyone assist with directing me to repairing the tilt steering that is very loose. I have used the Haynes Manual that takes me as far as removing the steering wheel and then that is about it further instructions are non existant and tilt steering is not even mentioned in the manual at all. Thanks for your experience.
Old 05-30-05, 11:05 AM
ironflea1
tilt steering
mike on the under side of the steering wheel is a spring that holds tenion for the tilt it could be broke or weak. should be able to see it after wheel is removed. also there are some bearings under the wheel you might check
