Oil Cap Leaking!
Old 05-30-05, 02:27 AM
LeBoOo
Unhappy Oil Cap Leaking!
Hey guys,
I have a 1994 Suzuki Swift GTi 1.3L DOHC,
I have found that after driving the car for 15 minutes, it leaks approximatly 1-2ml of oil from the oil cap onto the rocker cover..
The oil stick has oil on the interior part that gets shoved in the oil pipe.
I was told that the pcv valve could be blocked, but then I thaught if it had enough pressure to leak out of the oil cap then it could start pissing out oil from the oil stick pipe thingo!
Old 05-30-05, 03:41 AM
Lugnut's Avatar
The pcv valve is blocked. Replace it.
