Coolant fan on 1989 Cady
I have a 1989 Cadillac Seville. The "Coolant Fan" warning message keeps showing up on the console display. The fan does not turn at any time, even when the coolant temperature is above 200. I have removed the electrical connection to the fan and connected the fan directly to the battery. The fan works fine. I have also connected a volt meter to the electrical power plug which plugs into the fan. With the fan dissconnected from the plug and the ingnition on I get 12 volts. But if I connect the fan I get 0 volts. What would stop the fan from getting power ? What do I check next ?
The fan does work if I turn on the air conditioing.
Bob
Bob
Check the engine temperature sensor. Start by just unplugging the sensor when the engine is hot and see if the fan starts to run. If so, replace the sensor. You probably have multiple engine coolent sensors, so be sure to check each until you find the problem.
Do you have two cooling fans? If so, are both working when you apply 12V? The wiring diagram from autozone shows you have 2 fans, along with a fan control module, a body computer module, and the ecm which all are factors in the fan operation. Figure 84 at http://www.autozone.com/servlet/UiBr...3d8015922a.jsp
If not a temp sensor or one of two fans are not working, there could be a problem with one of the modules, hard to say how these work. My guess is that the ecm is detecting a short or too much current draw or a problem with a module, thus cutting off power to the fan, but that is only a guess. Look for another fan, apply 12V again and see it both fans are working, if you see 2 fans, and also check both fans with the A/C on then post back.
Yes 2 fan
There are 2 fans and both are showing the same problems. Neither comes on when the car get hot. Both come on when the air conditioning is on. Both work if 12V is applied.
I have not checked the temperature sensor. If I locate it I will check it out.
bob
bob
I don't know where the sensor is but could definitely be the problem. Hope you found it. You might also want to check the coolant level, thinking it could be too low to trigger the sensor.
Temperature sensor
I can not find the temperature sensor. I have looked on the radiator and on the block but I could not find it. If anyone knows where it is located please let me know.
As I said before the engine temperature does show up correctly on the engine data on the consol. So if the sensor that reads the temperature for the consol is the same as the one for the fan then it appears to be working. But I can not find that sensor either.
bob
bob
It is likely that the sensor for the gauge is a different sensor than the one used to control the fan. Don't ask why, it just happens. Look for anything screwed into the engines water jacet, manifold, etc.
When you find one, even just guessing, uplug the wire(s) to it while the engine is hot. If your lucky, your fan will start and you've found the problem. However, this is not always true about the fan coming on,, depends on the circuit design.
Found one however
I found a temperature sensor hiding near the distributor under the air cleaner ducting. With the key in the on position I unpluged it. The fans started up. Now here is the weird part. The sensor is the one used for the readout on the consol display. The consol display shows the correct tempersture when the sensor is connected. When I run the engne the consol display shows the temperature rising from anbient temperature on up. When I disconnect the sensor the consol displays a temperature of 195. What is going on here ? Since the consol display is reading the correct temperature from this sensor it must be working OK. But since the fans go on when I disconect it the sensor must be bad. What am I missing ?
HELP
bob
HELP
bob
