wildcat has bad gas
wildcat has bad gas
i have a 1970 wildcat. the gas is stale. will not start. it cranks right up with starter fluid. is there an easy solution or do i haver to drop the tank?
Is the gas stale or does it have water in it? Condensation will put water in the tank. You shouldn't have to drop the tank to drain. Just disconect the gas line. Sometimes adding 5 gal of high test along with a can or two of drygas will work but replacing the gas is always better than trying to doctor it up.
