spark plug rethreading
I have a 99 ford f250 v10 and one day while driving heard loud repeated bang under hood. After further inspection found ignition coil(1 per cylinder) laying on the intake. It cracked off and also found spark plug on intake. I figure that when the last owner had it tuned they must have cross threaded the plug as I couldn't put in a new plug. I bought a tap and retapped it and the tap goes in and out by hand easily now but a new plug only seems to grab 1 thread. Have tried 4 different brand plugs and 2 grab the other ones don't. Any ideas before I put an insert in. The plug grabs and when you continue to tighten- it comes out. Ill probably have to take the head off to do this. Not looking forward to this. Its an aluminum head too and its the second from the back, not easy to get to.Allready have the new coil. Any ideas??
Originally Posted by car nut
It sounds like you are going to need an insert. If done properly they are stronger than the original threads.
They work great
These heads are known for popping the spark plugs. They are designed so only 3-4 threads hold the spark plug. Any galling, cross-threading, or overtorquing will weaken the threads. Plus, the first few spark plug threads get carboned, and the threads take a beating when you remove the spark plugs. It sounds like you're beyond chasing the threads and a helicoil repair is your only choice.
So the only way to put in a helicoil is to remove the head? right? I have seen a double tap at the parts store(Auto zone) that starts with the 14mm tap and then follows with a larger tap to put in an insert which comes with it. You then put rtv high temp around the insert and turn it in. Is this the same or different then a helicoil?
It can be done with the head in place. The trick is to pack the tap flutes with grease to catch the shavings. Any helicoil repair I've done involved first drilling the hole to a certain size, then tap that hole to form the new threads. The helicoil is then inserted with either the special tool or it can be inserted with something like needle-nosed pliers.
Make sure you get some anti sieze on the other plugs and do not over tighten to reduce the risk of this happening again.
Originally Posted by thiggy
Question for Carnut - Why should you not use standard thread cutting oil on aluminum? That is the first time that I have heard this advise.
Winbro also makes tapfree for all metals except aluminum.
I have seen tapping fluid for steel actually smoke when applied to aluminum and the tap does not cut well at all. It actually will get stuck and sieze to the aluminum.
