Heater Fan only working on Hi speed??????
Old 06-06-05, 06:43 PM
Question Heater Fan only working on Hi speed??????
I have a 1999 Ford Contour. The heater fan only works on hi speed. Any ideas what I can check?? Thanks for any info.
Rick
Old 06-06-05, 06:46 PM
Lugnut's Avatar
The resistor stack is bad. Replace it.
Old 06-07-05, 01:45 PM
Thanks Lugnut
Can you tell me where to find the resistor stack, and is it hard to replace?
Thanks alot
Rick
Old 06-07-05, 06:20 PM
Lugnut's Avatar
I don't know where it is on your model but fords usually have them mounted in the engine compartment, then in the wall of the heater core chamber near the firewall. It will have about 3 wires plugged into it. Remove 2 screws, remove part, unplug wires. Reverse to install.
Old 06-07-05, 07:42 PM
Thanks Lugnut
I will give this a try and let you know how I made out.
Rick
Old 06-10-05, 07:01 PM
hspr's Avatar
Get the wiring harness too. They usually go in pairs.
Old 07-26-05, 03:16 PM
The reostat was behind the glovebox.
1 screw and $20.00 fixed the problem
Thanks
