1997 Explorer a/c/ problem
Old 06-06-05, 08:05 PM
Question 1997 Explorer a/c/ problem
My 1997, 6 cylinder explorer will only put out cold air when the control is set on "max a/c/ When the control is set on normal, the unit blows out hot air.
Help me somebody!!!
Old 06-07-05, 07:52 AM
Lugnut's Avatar
If the air is heated air, then check your heater control valve in the engine compartment, in the heater hose toward the firewall. They are easy and inexpensive to replace.
If the air is just warm outside air, then you have a blend door problem.
Old 06-20-05, 07:47 AM
1997 explorer a/c problem
to:: LUGOUT: I changed that heater control valve on my 1997 Ford Explorer; didn't change anything, stilll get very hot air on any setting except Max A/C. any other thoughts?
Old 06-20-05, 08:57 AM
Lugnut's Avatar
The heater control valve is vacuum operated. Check that it is working while someone throws the switch from heat to cool. You may have a vacuum leak.
Old 06-20-05, 09:54 AM
P
Check fuses 10 & 18 in the interior fuse block.
