A/C problems
Old 06-07-05, 01:03 PM
robert8082
A/C problems
The a/c belt on 1994 plymouth voyager keeps burning off or it will break off what could cause it and how can i stop it? the engine is a 3.0 L
Old 06-07-05, 02:17 PM
Lugnut's Avatar
My first guess is that your compressor is locked up. If so, it will burn up every belt you put on it.
Old 02-27-07, 11:57 AM
A
Lugnut hit the nail on the head. Your compressor has locked up internaly so when you hit the ac button it engages the clutch to turn the internal shaft which is locked so the belt will just slip on the pully.
Old 02-27-07, 02:15 PM
W
Could be fellas ....................BUT..............check the tensioner pulley.........nasty reputation for seizing up...........If it's OK, the compressor is the culprit (I always check the cheap stuff first)
