A/C only cools on the highway in hot weather
Old 06-08-05, 10:04 AM
zwagon1
Basically, when the weather warms up so does my A/C in my 1999 Isuzu Rodeo. The a/c will not cool off if I am in stop and go traffic in hot weather. However, once I am on the highway driving continuously, it will send cool air. I had the A/C shocked last year, but don't think I need to do that again. Any thoughts on what is going on with my AC. Thanks!
Old 06-08-05, 10:46 AM
Lugnut's Avatar
Probably just low on refrigerant. When it gets lower, it will shut off completely.
Old 06-08-05, 12:05 PM
zwagon1
Is that something that has to be replaced every year
Old 06-08-05, 12:48 PM
Lugnut's Avatar
You have a leak.
According to EPA law, a system cannot be topped off without first being tested for and repairing any leaks.
A leak can get worse fast and you could lose the full charge in a week. Trust me, it happens. On the other hand, 1 can a year may work. Time will tell.
Old 06-09-05, 10:20 PM
rav12's Avatar
I would also suggest checking if the condenser fan is working. If it is broken the airflow from driving may be simulating the fan and you get cooling as a result.
Old 02-27-07, 12:13 PM
A
Check fan operation, make sure the condensor is clean and free of dirt rocks and bugs.
But most likely you have a small leak, it would be a good idea to have dye added next time u have it charged so it makes it easy to find the smaal leak.
Old 02-27-07, 02:28 PM
W
Rodeos are good for fan clutch issues..........the truck probably is running a bit hotter than normal too
With the engine running CAREFULLY.............try to cop a feel of the airflow behind the fan........If the fan isn't throwing any air replace the fan clutch
Old 02-27-07, 02:36 PM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
You guys noticed this is a two year old thread, right?
Old 02-27-07, 10:48 PM
A
Please do not be argumentive.
