91 Explorer Window mechanism
Old 06-08-05, 02:21 PM
biddeford5
the motor works but the window doesn't transit up and down. in fact it will slide about half way down on it's own. there's a metal cable inside the door. how do I fix it?
Old 06-10-05, 05:56 PM
hspr's Avatar
The window regulator -- the apparatus that supports the window and transmits the power from the motor to the window -- is probably broken. A bit of a tough repair, can be dangerous because the mechanism is probably springloaded and can snap closed on you. Requires removal of door panel and taking out all of the guts. Too much to explain here. Get a repair manual if you intend to do it on your own.
