12 volt Generator check
Old 06-09-05, 03:44 PM
Inky's Avatar
Question 12 volt Generator check
How do I check a generator to see if it is charging? It is on a 1978 Kubota tractor.
Old 06-09-05, 04:02 PM
Lugnut's Avatar
A simple indicator would be to read battery voltage with engine off. Then read battery voltage with engine on, and it should be a higher voltage.
Old 06-10-05, 04:38 PM
Inky's Avatar
Lugnut,
I know it is not charging, I just don't know if it is the Generator or something else in the charging system.
Thanks,
Old 06-10-05, 06:21 PM
hspr's Avatar
If not the generator, then it is the regulator (assuming it is not built in to the generator) or the battery itself. To test the regulator I would disconnect it from the system, set up your meter on the battery as Lugnut suggests and -- ** only for a very short time ** -- start the engine and see if you see the voltage rises.
This does not rule out the battery. I suggest you take it out and have someone load test it. Anywhere that sells batteries should be able to do this.
Old 06-10-05, 06:48 PM
hspr's Avatar
Pardon me, brain fart. If when you remove the regulator the generator charges, then it is the regulator. It would only be the battery if it didn't hold a charge.
