2000 toyota corolla -- brake light
Old 06-10-05, 06:33 PM
jin
so i own a 2000 corolla. right brake light isn't working. the tailight is fine. i don't have the manual since i bought the car used and currently the only other manual i could get a hold of is about 40 miles from me. what should i do to fix the brake light? any help is great
Old 06-10-05, 06:52 PM
hspr's Avatar
Have you tried to replace the bulb ? That only one side works means the brake switch and most of the wiring (except the piece that goes from one side to the other) is fine. The parking light and brake light are probably the same bulb, which also rules out the socket, but the bulb has two elements. Open the trunk and look for access from the back. Otherwise look for a some screws that will release the housing.
Old 06-10-05, 09:00 PM
jin
yay it works now. XD
