interior aftermarket lights
Old 06-13-05, 02:09 PM
dahall69
ok i purchased interior light for my vehicle along with an inline fuse i ran the ground to a good ground and the positive to the positive termanial on the battery, for some reason it wants to keep melting the wires and shorting out , how do i hook this up?
Old 06-13-05, 04:22 PM
what size wire
What kind of light is it?dont use thin wire use the correct guage the thicker the better.Make sure wire is away fron sharp edges that can cut or rub thru it.Also keep in mind the longer your wire run is the thicker the wire must be.
